Need more power!!!
C1500martin
Hit my first comp today and was disapointed so now i need more powahhhhh! My question is since i have 2 d1 subs i can only wire to 1ohm. What i was thinking is running an amp per sub at .5 each amp, i had sq4500 in mind. What would happen if i strap them at 1ohm is it the same thing? Each amp will see .5 although they recommend 2ohms. Is this super dangerous? Should i just run an amp per sub and gain match? I have access to a cc-1 and dd-1
since my box rise is so high i should just gain match the2 amps at .5 instead of buying say a xfire 8k right? its more benefitital? plus it'll be a lot cheaper with the ams at 600 this friday or if i buy used even cheaper might even be able to keep it under $1k for 8k watts
only thing i dont like about gain match is due to the slight variations in the power each sub will get, seems like internal circuitry handling that and making it equal would be more beneficial to eliminate phase and other issues, but then again who knows it might be so small in variation that we couldn't audibly hear it.
Is it the same thing though? if i gain match or strap? regardless my amps will see .5 each? but strapped is it more dangerous or is there no difference at all. .5 is .5 strapped or separate?
cool so i guess its set, anyone know somebody selling an sq3500? might get the one on caco if i can find a matching one, save myself some decent mula$$$
Every time i strap, its always weaker than if i gain matched. Rise is usually higher too.
C1500martin
C1500martin
Cali
Papermaker85
