Have recently ran into some major financial set backs and must sell the system out of my truck. All prices are OBO, please do not be afraid to make me an offer.
MTX 7801 Sub Amp - $325 shipped
Thunder Super Amplifier
Prizm EFX: Selectable Lighting Color, or Pusate to Beat
Xtant Technologies Cooling: Thermal-Regulated, Turbo-Charged Intercooler
RMS Minimum Power Rating:
400 Watts x 1 Channel @ 4 Ohms
800 Watts x 1 Channel @ 2 Ohms
1200 Watts x 1 Channel @ 1 Ohm
Wired EBC Remote Subwoofer Bass Level Control Included
CEA-2006 Compliant
Power and Protection LEDs
-12 - +12 dB Bass Control
Variable Bass Control Frequency: 30 - 80 Hz
Onboard Crossover: LP (40 - 200 Hz), Sub (30 Hz)
Semi Unregulated MOSFET Power Supply
High or Low-level Input
Adjustable Input Sensitivity: 100mV - 1V / 1V - 10V
0 Gauge Power Connectors with Built-In 4 Gauge Capacitor Terminals
Wired Bass Remote Control Included
Frequency Response: 20 Hz - 200 Hz
Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
MTX 7804 Speaker Amp - $325 Shipped
Thunder 4-channel Super Amplifier featuring patented class A/B output
100 watts RMS x 4 at 4 ohms, 200 watts x 4 at 2 ohms
400 watts RMS x 2 bridged output at 4 ohms, 800 watts x 1 front/rear summed output
Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
PrizmEFX accent lighting effects - Customizable to match your vehicle's interior
Semi-unregulated MOSFET power supply
Overload and thermal protection
StreetWires connection terminals
Variable electronic crossover at 40~350 Hz, selectable 12 dB Hi/24 dB Low Mono, defeatable
Bass boost at 40 Hz, 0~18 dB/octave variable
A.R.C. (Active Resonance Control): Cut 0~15 dB/octave, Freq. 200 Hz
Input (RCA connection): Low-level, hi-level w/Smart Engage
Input sensitivity: 100mV-1V/1V-10V switchable
CEA-2006 Compliant
Tsunami LITEWAVE Series PP1002TM - $60 shipped
2-farad wedge-style capacitor (24-volt surge)
blue LCD meter
flashing blue LEDs
blue LED accent ring
audible low/high-voltage warning
2-gauge positive and negative wiring terminals (4-gauge adapters included)
Kicker RS65.2 Component Speakers - $200 shipped
6-1/2" RS Series 2-Way Component System
Power Handling:
Peak: 400 watts per set / 200 watts each side
RMS: 200 watts per set / 100 watts each side
CIMP™ (Curvilinear Injection-Molded Polypropylene) cone woofer
Optimized composite rubber surround radius
1" Teteron elliptical dome tweeter with neodymium magnet
Enhanced BAM (Basket and Motor) Assembly
High-dampening strength cast aluminum basket
4 ohms impedance
Coaxial tweeter mounting option
Newly designed passive crossover network
Spring-loaded nickel plated terminals
High-temp polyimide film voice coil former
Ferro-Fluid™ cooled tweeter voice-coil
Polk DB460 coaxial speakers - $40 shipped
Recommended power range: 4-40 watts RMS
Peak power handling: 120 watts
Frequency response: 75-22,000 Hz
Sensitivity: 91 dB
2-way 4"x6" speakers (pair)
polymer/mica composite woofer with butyl rubber surround
liquid-cooled, silk/polymer composite 3/4" dome tweeter
2-way crossover network
suitable for marine use
top-mount depth: 1-15/16"
CEA-2006 Compliant
CEA-2006 Compliant
blue LCD meter
flashing blue LEDs
Power Handling:
4 ohms impedance
Sensitivity: 91 dB
