Need help!!!
burick701
21
NJ
I just bought an Alpine 9847 like a week ago. It was running fine and then it blew a fuse. Not on the HU itself but in the circuit box. I replaced it and it worked again. But like a half hour later it turned off again and switched fuse again but it blew again. Took HU out then put it back in and it was working again for a couple days. All the sudden it blew again. What would be causing this????
make sure you don't have too much of a load on that fuse, i had a friend who had an audi and EVERYTHING was connected to one fuse. If this is the case i would run another fused wire or get a relay.... just my 2 cents
i'm not sure what fuse it is. It just says radio on the circuit reference. It is the one inside the car under the dash. it is a 7.5A fuse.
check all your power wires 12 volt constant, ignition etc... make sure they are fastend tight and put some electrical tape around the connection. Your power wires are probably hitting a ground in turn causing your fuse to blow.
Thanks for the help. I taped all the wires away from the ground and it is working fine. THanks for your help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
burick701
burick701
NJ
burick701
