Derek King
CarAudio.com Newbie
Ok so I have an old deck and speakers laying around, and I want to hook it up in the garage. I just need to know the best way to get some power to it. Tia.
Gotta add a cigarette lighter socket while you're at it.I would probably recommend something bigger than a 5 amp power supply. Most radios require at least 10 amps. You will know for sure by looking at the size of the fuse on the back of the radio. Whatever that is, look at adding another 5 amps so your power supply isn't working so hard. I know it is not common for people to blast their radio to the max, but what if they do? Also, a bigger power supply will allow you to hook up other things like a phone charger plug or... Amazon has 12 volt 20 amp power supplies for $25.
I would build a box, which is preferably sealed. A 1 cubic foot would be fine. You can use wood. Then cut the holes for the radio and the speakers. The radio and speakers can share the same space in the box. If you are using more than two speakers, make the box a little bigger. Do not install the power supply inside the box. It will get too hot. However, it will be a good idea to have some type of a cover above the power supply if it is one with a perforated lid. You don't want dust and debris to get in it.
It is funny how I have not seen many of these setups without a cigarette lighter port.Gotta add a cigarette lighter socket while you're at it.![]()
Did it as a kid, and I still get very real chills up my spine thinking about it.Were you playing with the cigarette lighter again?
