need help.
  • 2
tat2
mass
i need some help, some one tossed me a box plan but it's to deep.
Here is the design that I did for my buddy. It is tuned to 40 Hz
This is for a dual chamber box. External measurements are 14" tall x
31.25" wide x 30" deep.
(2) 30" x 31.25"
(2) 13.25" x 12.5"
(3) 29.25" x 12.5"
(2) 12.5" x 11"
(1) 12.5" x 29.75"
i need it to be 25" deep. how would i go about resizing it. i can go tall and wider, i just don't know how to do it and have it the same all aroundsize and tune.
and should i keep it tune like that, it'll be in a jeep off a pg t1200.1 i like lots of spl and like to hit pretty low. if i need to change the tuning how do i do that also.
thanks.
35" wide x 25" deep x 15" high will get you the same numbers...
top/bottom: 25" x 35" (2)
sides: 25" x 13.5" (2)
middle: 23.5" x 13.5" (1)
front: 13.5" x 28" (1)
back: 13.5" x 33.5" (1)
port: 13.5" x 14" (2)
This will give you 2" x 13.5" ports and tune it to 38Hz. The ports are on the outside edges and the middle is not seen, hence the single front baffle.
657
721
957
tat2
tat2
mass
Trixter
    May 16, 2024
    May 16, 2024
