Need Help!
StraightUp
Hello everyone,
I'm hoping I can figure out this problem I have with my audio setup. I would appreciate any help I can get as this is a big pain. This is kind of a long story but I will try to make it short, if you need me to clear anything up, please ask. On a side note I'm not very mechanicaly/electronicaly/audio inclined. lol
So here's the deal:
My buddy and I have basically the same setup. We have mazda6s with ported boxes for 2 10's. We both have Rockford Fosgate P3 4ohms. But his are shallow mounts and mine are the regular subs. So I'm expecting mine to hit harder, but his are way **** louder. Mine aren't even close, it's ridiculous. On the amps he has a older RF 2 channel 600 watt amp, and I have a SSL 2 channel 1000 watt. Your probably thinking it's the amp, but we switched amps tonight to test, and mine still is not living up to my expectations. What could it possibly be??? I'm starting to think there is something wrong with my subs.
Definitely a headache. Thanks for the help
Shallow:
Size 10"
Nominal Impedance Dual 4-Ohm
Power Handling 300 Watts RMS
600 Watts Max
Voice Coil Diameter 2.5" 4-Layer
(6.35 cm)
Magnet Weight 46 oz.
Speaker Connector Dual 10 AWG compression
Fs (Hz) 45
Re (Ohms) 6.80
Le (mH) 3.6
Qms 4.50
Qes 0.87
Qts 0.73
Vas (Liters) 10.4
Sd (cm2) 310
SPL (dB @ 1w/1m) 83 dB
Xmax (mm) 10.8
Woofer Displacement 0.061 cu. ft.
(1.73 Liters)
Cutout Diameter 9.0 in.
(22.86 cm)
Mounting Depth 3.50 in.
(8.89 cm)
Shipping Weight 13.40 Lbs.
(6.07 Kg.)
Regular:
Subwoofer Size 10"
Subwoofer Design Round / Circle
Main Cone Color Black
Voice Coil(s) Dual
Impedance (per voice coil) 4 ohms
Peak Power Handling 800 watts
RMS Power Handling 400 watts
Woofer Composition Kevlar Fiber cone
Woofer Surround N/A
Minimum Sealed Box Volume 0.50 cubic feet
Maximum Sealed Box Volume 0.75 cubic feet
Minimum Ported Box Volume 1.40 cubic feet
Maximum Ported Box Volume 1.40 cubic feet
Sensitivity 83 dB
Frequency Response 29 - 250 Hz
Xmax (millimeters) 16-3/16 mm
Top Mount Depth 6-1/4"
Shallow Mount Installation No
Cutout Diameter 9"
Recommended Enclosure Type Ported / Vented
Sealed
Subwoofer Grille No
Re-Cone Kit Available No
im just taking a stab here but i think he ment that he wired his coils in series to 8 ohm then in parallel to a 4 ohm load and bridged his amp. Check all your wiring one sub may be out of phase.At least your going about trouble shooting the right way by eliminating possible culprits. check the amp settings too
StraightUp
StraightUp
Ohio
StraightUp
