need help
wired series/parallel your 3 dual 4 ohm subs will come out to 2.67 ohms which by that spec sheet will still give you 600 rms(200 per sub)
so i COULD run all of those subs on my amp without blowing/ruining it? some guy told me i could, and then another said i couldnt.. would it even sound good though since it would be taking 200 rms from each
which they will do decent off of in the correctd enclosure. ive heard a pair off 200 each they are okay for the underpowering theyre getting. these arent power hungry monsters here
u can do it but u will need to send the sub's some more power . i would get a new amp cuz those subs can take a tad bit more power. 1500 at 2 ohms is about right. u should get 2 12s and get a new amp and b able to wire down to 1 ohm. i had 3 dual 4 ohm subs and i had a sundown 1200 and i came out to 2.67 ohms. my subs about 250 rms each it was ok at best.
yes it can be done..can sound good and not blow anything.
in the future would be better with a 1200-1800 rms amp at 1ohm..if its a quality amp and we upgrade some electrical you could wire them to parallel and .67 nominal would cause the amp no harm..
hmm.. i dont have any money to pay for like a $500 amp lmao.. i was just hoping to run 2 of the subs off of the amp i have and then one off a new one i could buy for like $150, i figured i could even if they were all in the same box, i guess not
Dmatt
Dmatt
Florida
cj407
