need help
Uh oh.... Hope you didn't have some kinda of "backfeed" does the amp come on in protect? or does the pretty green/blue light come on. If the amp doesn't go into protect. First thing I would look into is the head unit. If the head unit went down obviously the amp and the subs would too. Just wonder if you shorted something out in there. If you have a highs amp hook it up to rca's and see if it works. if not you prob found your problem
o no i took the box out and the pos wire on the terminal fell off. would that cause the h/u to turn off. but i hooked the wire back up and itworks perfect,
95_venger
95_venger
demotte
audioarsonal
