Need Help
boarderkid1121
7
Mass
I just bought a car with a system already in it so i knew nothing about it. this is what happened
My Ground and my Power supply wires came out so i was putting them back in.
the installation was crappy from before and the wire ends sucked
while screwing them in they touched and sparked, alot and loud.
Ground wire has burn marks so i figured it was burnt and the fuse blew.
Then:
Got new Ground, Got new fuse (was a 60amp put a 80amp in, amp had 2x40 so i figure it should work)
It didnt work, then i tried it the next day, it worked for 2 min then stopped. duno what the problem is. fuse is fine.
nah they good just looked earlier. My only guess is my Power feed wire is fried or the amp is fried. I would take it to a car audio place but i cant get the car on the road for a few days.
ya i took them out, no sign of a blow or disconnection. could my feed wire been fried when it touched the ground. they touched while semi connected to amp =/ i dont kno whats wrong
i wouldnt kno how to do half that stuff, think ill just wait till i register it at the end of the week and take it to this place my friend knows ppl at.
save some money man take the remote wire off the amp take ur pos. lead on the dmm and ground the ground lead of ur dmm with metal. turn ur radio on and see if u get a reading . if not theres ur problem
or take ur amp out of the car and take it and wire it directly to a car battery and run a wire fron the pos batt. post to ur remote and see if the amp turn on
boarderkid1121
boarderkid1121
Mass
blackbonnie
michigan born
    May 14, 2026
michigan born
    May 14, 2026
