Need Help
Bubba88
Tha King
Ok I got my components in today and I already have wire running for my amp from when I had my subs hooked up. Well I tried to hook up my components with the speaker wire to the amp. Well all I got played through my speakers was bass, I could barely hear the words and my tweeter made a weird noise. What did I do wrong?
On one of my HU's, it has the ability to switch the sub output to a normal output, check you're manual to see if you're HU has this feature, also you could simply shut off the internal xover and if those don't work for you, buy a line out converter so you can use you're regular speaker outputs.
My HU doesn't have that and I don't want that anyway because I will be putting my subs back in pretty soon with a different amp so I will have two. There has to be a way to do this.
Owners manual, did you read it?.
I bet 50 dollars that you have not, and I bet another 50 dollars that the solution to you're problem is in there. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Edit look for this-
» Front Image Enhancer sends only low frequencies to rear speakers (switchable)
Its one of the features of your hu, when activated it cuts the high frequencys from the rear to make the fronts seem brighter, referr to your manual on how to shut it off.
Ok I understand that but do I still hook up the RCA's into that same output? Because soon I will be getting another amp for the subs and have a splitter there. Is it alright to have both the RCA's hooked up to the same output?
Bubba88
Tha King
Bubba88
Pascagoula, MS
jsloan10
