Need help with wiring.
I need help wiring a DVC sub that is 4 ohm per coil. Since my 2 channel amp isnt stable at 2 ohms mono, would i get more power running it bridge in a series or running it with both channels to each coil?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Originally posted by vega5150 I need help wiring a DVC sub that is 4 ohm per coil. Since my 2 channel amp isnt stable at 2 ohms mono, would i get more power running it bridge in a series or running it with both channels to each coil?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You might as well run one channel on each voice coil. Ur amp have a mono/stereo switch?
Radio have a subwoofer output, it might be mono.
I alrdy tried running it parallel and the amp would get really hot and after playing it for about 5 minutes or so the protective mode would come on.
The amp doesnt have a mono/stereo switch, and the HU doesnt have a subwoofer output.
So I should run it one channel on each voice coil?
Thanks for the help.
Originally posted by vega5150 I alrdy tried running it parallel and the amp would get really hot and after playing it for about 5 minutes or so the protective mode would come on.
Yeah that is about your best best for now. Just run the amp in stereo and put one channel on each VC. Unless you get another sub just like it. Then you can wire the pair up in a 4 ohm load and bridge your amp.
Or get a 1ohm stable amp.
do it just like that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
vega5150
vega5150
Los Angeles, CA
avistar23
