Need Help With Wiring My System
mtzhoodlum
Here's The Deal. I Have 1 10" Kicker Sub That Is Going To Be Pushed By A Profile Mono Amp. It Says 350x1. Then I Have A 4-channel Amp Running My Front And Rear Speakers. It Pushes 60x4. They Are Going In My 66 Bug. The Amps Will Be Right By The Battery. I Want To Run A 4awg Off The Battery To A Block And Then Run Two 8awg To The Amps. The Ground I Want To Run Two 8awg To A Block And Then Run A 4awg To The Negative Terminal On The Battery. I Need Some Advice On The Wiring That I Should Use. I Have Never Heard Of Knukonceptz Before I Went To This Website. I Have Been Looking At Streetwires, Stinger, Etc. Any Advice I Would Definetly Appreciate. It's Not A Monster System, But I Want It To Sound Good.
knu is less expensive, and i just received 20 ft 1/0 from them with no issues in 3 days:D...
mtzhoodlum
mtzhoodlum
Martinez, CA
2critical
