Just bought this "convertable" component set. Meaning it can be used as seperate tweeter and woofer, or you can screw the tweeter onto the woofer and use it as a 6.5 inch coaxial. Well im doing the components. So i unscrewed the tweeter from the woofer. My problem is that i cant figure out to set it up now.
So theres the tweeter on the right, then the mounting bracket in the middle, and i think some how im supposed to attach the thing on the left to the back of the mounting bracket correct? Or do i connect it to the back of the tweeter then put both in the bracket?
So theres the tweeter inside the bracket without the other thing attached.
Back of bracket with tweeter inside. Im GUESSING the wire thing attaches to the back of the mounting bracket since theres a hole in the center of both of them. But i cant get it on there good. Like i pushed it on really hard and it doesnt seem like it would come off easily but at the same time isnt all the way in the holes if that makes sense. Like the metal prongs are not touching the back of the tweeter,
Is this done correctly?
