YoungBloodM50
Ha ha! I was just about to correct my last post about the coil configs. Your right, they only produce a d1 and d2
I now see the 2.5's. Those are only dual 4's so the wiring options are limited. You can only wire 1 of those to a 2 or 8 ohm load, or 2 of them to a 1 or 4 ohm load. Also, the 2.5's are only rated at 600 watts rms, which isn't bad at all, but quite a bit less than the hdc3's. Take your pick, save a little green with the 2.5's or get the better one's. Check the classifieds too, I have seen a couple of the hdc3's in there. You might be able to get a deal on some used.
