first off your amp doesnt double its lower by adding 2 volts, so go back to the drawing board on that one. I think you should go with the Solo X but thats just because I've had some and I liked them.i am confused i have rocford amp of 750 rms @12v 1600 rms @14v. and i want to install it in the ski pass and dynamat the boot, so shall i chose im into jungle rap hiphop, so kicker solo x 10" or jl w7 10", which 1 please advice
stick with jl. the new Re is not as it used to be in the pass before US amps bought it. and always go by the RMS wattage than Peak or Max watt. thats how ppl buy the subs with 4000 max watts(which should put out at least 1500rms-2000) and end up blowing their subs.thats fine i was thinking about that any way, what do you think is the best between these two jlw7 12 1000rms or RE AUDIO MX12D1 MX 12" 3000w.
