need help with system
Alpine MRP M850
CEA-2006 Power Rating
CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 100dBA (Ref. 1W into 4Ohm):
500W x 1
RMS Power (at 14.4V THD+N, 20Hz-200Hz)
Per channel into 4 ohms: 500W x 1 (0.08% THD)
Per channel into 2 ohms: 800W x 1
* • Class-D
* • 1 Channel (Mono) Operation
* • Thermal Management Processor
* • Subsonic Filter
* • Bass EQ Circuit
* • Selectable Crossover (LP)
* • Adjustable Crossover (LP)
* • MOSFET Power Supply
* • DC-DC PWM Power Supply
* • Discrete Pre-Amp Stage
* • MOSFET Final Outputs
* • STAR Circuitry
* • Auto Over-Current Protection
* • Top Mounted Blue LED Power/Status Indicator
* • Gold Plated RCA Input Connectors
* • Continuously Adjustable Gain Control
* • Speaker Level Inputs
* • Gold Plated Power Screw Terminals
* • Gold Plated Speaker Terminals
* • Non-Fading Pre-Amp Output
* • 4-Layer Glass Epoxy PC Board
soo what do i do ? im sorry im new to this.
http://mobile.jlaudio.com/products_subs.php?series_id=4
its JL w6v2's
can you take a pic of your wiring with the woofers inside the box? I think I know your problem. only thing is when you do wire the woofers correctly you will be running them at 4ohm's... you may wanna try and get a 1 ohm stable amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ya im almost 100% sure you wired it to 2 ohm there then when the other woofer is wired the same way you have a 1ohm load.
both woofers are the same like that.
its connected at 2ohms for both speakers. thats how it originally came.
so then what now ?
daicacharco
daicacharco
San Diego. CA
daicacharco
