Need help with remote turn on
khmer_rouge
VA
hey guys, everything was working fine, I was driving down the road and the remotes from both amps came loose from whatever they were connected to. I wasnt for sure what they were connected to but obviously they werent connected to my audiocontrol dqxs remote. I connected the amps remotes to the remote at the point of the audiocontrol plug(For the time being, I know thats not good). One of the amps is now working fine, the other never really came on, it was going into fault mode, obviously it wasnt getting enough of a signal to turn on correctly. Where should I rerun those 2 amp remotes to? I think they were connected to one of the distribution blocks but not sure which one. I was thinking the amps would stay on constantly if connected to the power dist block, or would running the remotes to the ground dist. block be ok? Anyway, I need to know where I need to run these remotes to.
Keep in mind, I have a line driver, a digital eq, and 2 amps(adding a 3rd) and I dont want to split the remote wire 4/5 different ways from the headunit. I need to get that turn on from some other area so that there are no issues with not getting each component enough signal to turn on and work properly.
relay with a seperate 14 awg power wire running to it fused at 7.5 amps, should be no problems....
khmer_rouge
khmer_rouge
VA
draarong2004
