badbelaire
Hi I am new here and hopefully someone can help. I have a 67 impala fastback that I am doing the stereo system for right now, it is going to have 4 6x9s in the rear deck, 2 6.5" in the doors, and 2 4" in the kick panels, and a alpine 15" type R 1522d under the rear deck. the sub is going to be wired for 1 ohm as it is a dvc 2ohm woofer, the amp is a alpine mrd-m605 (600watts rms). All of the other 8 speakers are going to be wired in parallel so that I can run all 8 speakers off a alpine mrp-f250 (50watts rmsx4) 2 speakers per channel. The main question I have is about the 4" tweeters, they are rated at 30watts rms, will they blow in this setup? If so can I wire them to run off my stereo which is 18wattsx4 and run the other six speakers off the amp. If so, can I combine the 4 channels on the stereo so 2 channels go to each 4" speaker for appx 36watts.
also in the scenario where I wire the 4" to the stereo, will I be able to balance the sound to match the amps.
I hope I didnt confuse anyone, I could sure use some experienced opinions. thanks alot and all have a great new year.
