loud_mouth22
i purchased this amp new a few years ago and had the shop i bought it from install it with some 10 in kicker cvrs that i bought from them also they are 2ohm dvc and never seemed to hit hard i had lost the manual but after looking at the wiring diagrams on this site i see that this amp was seeing a 4ohm load to the imputs where it shows it can handle a 2ohm min. at the amp and i also remember that i belive that the amp is wired parallel inside so if you show the amp a 2 ohm load where you wire it in it will drop it to a 1 ohm load is this correct can someone pull out their manual and explain it better
