jiggy2dmax
I got a deal on a Eclipse 33430 Premium and decided to snatch it up. However, it did not come with a Manual so im unsure of how the settings should be. I want to bridge the amp to run a set of components. It should do around 275 a side bridged at 4 ohms. My question is that to have it run this way, how should I set the settings on the pics below. If anyone has a manual or a amp similar to this one, that would be great. Thanx. Also, im assuming that the bridged output will be the Left Negative and Right positive on both the left and right outputs. Thanx Guys!!
From the looks of it, the little dip switch should stay where it is or am I wrong? If someone could explain to me the function of each side of the switch(mono, Stereo, L+R) that would be greatly appreciated. Thanx guys!
