Need Help With Dvd Bypass
the wire that goes to the e brake is green its says it goes to the hot side of the e brake switch your saying just to ground it to the chassis
take a relay: 87 and 86 to ground, 85 take to your amp turn-on wire, and 30 goes to your parking brake wire and you dont need a toggle switch. This is also work on the AVHP4000 Pioneer. hope this helped!
This was just what I was looking for , thanks. I didn't think I'd ever find it, even using the search function.
hook up a toggle switch of any kind. One side connected to brake wire other connected to ground. When the units on, flick the switch on then off, and you're good.
Is there any way to wire a relay to the switch so tha the bypass happens automatically??
connect the e-brake wire to your ground wire coming off the deck. It's what i do and its worked on a sony, jensen, jvc and dual. im not sure about the pioneer, but its worth a try
does not work with pioneer's.
easiest thing to do is ground the wire that runs to the parking brake usually a pink wire. ground that and you should be good man
That would work with older Pioneers but all the new models have to see a ground pulse, so to do it the easy way you will need a toggle switch, but you will have to manually do this every time you start the car to bypass the unit.
MRC
MRC
DAYTON OH
csu87
vegang
vegang
