Need help with calculations from Ported box Sticky
Fi SSD12 used for reference.
Vd = Sd*Xmax
Vd = Sd (M^2) * Xmax (Meters)
Vd = 0.048 * 0.021
Vd = 0.001008
dV >/ 39.37*(Fb*Vd)^0.5
dV >/ 39.37 * (Fb*Vd)^0.5
dV >/ 39.37 * (35*0.001008)^0.5
dV >/ 39.37 * 1.878297101
dV >/ 7.394855687
dV >/ 7.39
A = Pi*R^2
A = Pi * R^2
A = 3.142 * 3.695^2
A = 42.89870455
A = 42.90
And you end up with 42.90 In^2 minimum vent area with tuning of 35 Hz.
You are welcome and I believe it doesn’t from what I have seen skimming through it just before doing this for you.
Lv = [(1.463*10^7R^2)/(Fb^2*Vb)] - 1.463
How about this equation ... 1.463x10^(7R^2) ..... comes out to be a number to the 40th power.
BTW: Numbers I'm using are:
for a TS/W106DVC Pioneer Premier. Have it laying around and I want to build a ported box for it.
Fs 35.4
Qms 10.46
Qes 0.52
Qts 0.5
Vas 0.955
Rms 2.453
Mms 115.49
Cms 1.8x10-4
Diam 7.9in
BL 17.62 (8Ohm)
8.81 (2Ohm)
Xmax .45in 11.5 MM (0.0115 meters)
Vd = Sd*Xmax
Vd = 0.048 * 0.021
Vd = 0.001008
dV >/ 7.394855687
dV >/ 7.39
A = Pi*R^2
A = Pi * R^2
A = 3.142 * 3.695^2
A = 42.89870455
A = 42.90
Where did you get 3.695 from?
ultimate157
Engineering Student
ultimate157
Worcester, ma
ultimate157
