Need help with an alt issue
TurdFergueson2
Team D.O.A.
I got my alt installed Friday and when it was first hooked up, I got a 14.2 reading. My mechanic drove it home about 5 blocks while I trailed and it was still fine.
I got in maybe 10 minutes later to give it the test. I popped the face on my radio which displays the voltage and it was still 14.2. I took off around the corner and gave the car a little gas and around 40 mph the voltage suddenly dropped to 12.7 and slowly dipping lower. Battery light popped on too.
Yesterday was rainy so I didn't mess with it. Today I tried a few things none of which worked. I put my DMM on the alt and it reads 12.3 (same as batteries)
I'm not sure what else I can try. My trusty stock alt was giving me a 13.5-13.9 reading when it was taken off. I swapped it because I am running 3k+ watts and may do more.
Does this sound like a bad alternator? All of my connections are tight, the belt is not slipping and it did work for all of like 15 minutes.
Car is a 2000 Chrysler 300M. I'm not sure if there is a fuse or something that I can check. I just don't want to go through the trouble of having it taken off and put back on if something else can be tried first.
TurdFergueson2
Team D.O.A.
TurdFergueson2
Chicago
TurdFergueson2
vegang
vegang
