Need Help with Amp Choice
CannMann21
BC
ok so i recently just bought 2 alpine type R 12" subs and now i need amp. they are the swr 1222d model which is the dual 2's i believe. now i have been reading up on amps a bit and i think i need a mono amp? will i need two seperate amps for the 2 subs or one bigger amp to power them both? the guy i got them off said, the biggest downfall when people buy type Rs is that they under power them with their amp choice. also i have seen some systems with capacitors. will i need one or will it not be necessary? (also heard something about the big 3 upgrade, not sure what that is)
if someone can explain these to me and possibly give me some good amp choices, that would be great, i have no idea what to buy.
sorry for all the questions, im fairly new to the car audio stuff and im still learning.
big 3 will help what size alt do you have ? u need 12 to 1500 watts at 2ohms or .5 so i would go with an audioque 2200 that way u could run it at 2ohms and be fine and if you ever wanted to upgrade u would be good with power, also thats a no go on the cap they are a waste of money
i dont have a car yet, the one i was going to buy is getting fixed because it got broken into. ive had a few suggestions for the alpine mrp m1000 so far but ill look into the kicker and phoenix ones too.
thanks for the help so far, any other suggestions for anything that can help me are appreciated
CannMann21
CannMann21
BC
CannMann21
