NEED HELP with a system with an MA HK4kd
GrandCherokee
what are the best subs i could get for around $350 or lower if i get an MA HK4kd.
my top system in mind is an FiQ 18" with a Sundown1500. but lately i noticed i could get a huge amp for cheap...and wondering if you guys have a good setup in mind
I have a Jeep Grand Cherokee and Im willing to use all the room back there...
SQL ftw I want loud clean bass
It depends on what you are going to run. If you are looking to run an Fi Q..sure, you'd only need 1500 watts. But if you need to run 2 subs at 1500 rms each obviously you arent going to get the sundown.
The MA is a great amp, I ran the visoniks for a couple years, and I currently run an 802sx and have had 0 problems out of either. I beat the crap out of them also.
Price is a big issue too, depending on what you want to spend. Both of those amps are around the same price though...
Decide on sub(s) or amp first...that way you have an ohm load to shoot for.
GrandCherokee
GrandCherokee
Orlando, FL
avs20
