need help wiring subs parallel or series
Dlh_tank
i have 2 audiobahn eter. series at 4ohm dvc - bridged 2300hct by audiobahn - im really new to this wiring stuff so could someone help with wiring options on wether to wire them in series or parralel . to be honest with anyone who can help me i dont know how they are wired right now other than all positives and negatives on both voice coils are wired together. anyones help would be appreciated.god bless.
A pair of dvc 4's give you 3 wiring options (only 2 are typically used) - 1, 4 or 16 ohms.
The 2300hct (when bridged) is rated at 600w at 4 ohms and 2400w at 1 ohm.
Since your subs are 1100w each the 2400w option makes the most sense.
Keep your amp's gain set on the low side and it should get ridiculously loud.
You should know though - 2000w+ is asking a LOT from your car's charging system. If you're looking to play it loud very often you should be prepared to make an alternator upgrade.
Dlh_tank
Dlh_tank
chipley,florida
n2audio
NorthFramingham
    Jun 30, 2026
