Need Help Wiring Subs and Properly Setting Amps
JakeM
First of all I dont get wtf
Sqrt(Power*Resistance) = Voltage
means. So im hoping you guys can help me.
Sub Amp-Clarion DPX 1000.2
Putting 2 RE 12 (4ohm DVC) this is how im going to wire them
My amp is
250x2 into 4ohms
450x2 into 2ohms
1000x1 into 2ohms
So if I wire the subs like I showed you and bridged it to the amp I would get about 500 to both subs or 250 to each, right?
Ok also how many volts(using that formula above) would I need to set my gain to?
Also should I switch the amp to Mono?
Ok now that thats over I just got in my Clarion APX 200.2 and PG ZR 6.5 Comps
PG=4 ohms each
Clarion=50x2 @ 4ohms
So how would I do that dam formula?
Sqrt(50*4) = 14.142735
Am I Right?
Dont wire the subs to a 4ohm mono load when you can get 450 to each sub. Wire each sub in its own parallel circuit and connect each to a channel of the amp. That is 450 to each sub since the amp is rated at 450X2 @ 2ohms.
As for the voltage, according to your formula, take the power you will be sending, which in the sub stage would be 900, multiply that by 2 and take the sqrt of 1800. Although I am not sure about what ohmage to use when doing a 2channel amp, I believe this is fine.
JakeM
JakeM
Houston
JakeM
