Jdevon708
Hello all, I have so-so skills/experience with car audio and needed little bit of help getting my unit working.
The stereo I'm putting in is the Clarion Max 385VD. It is Going into a 2002 Monte Carlo SS. Now I had a different unit in my car before but It got stolen. So now were on to the fun part. I managed to figure out what I thought was all of the wiring by going from the car plug to the adapter plug and then to the radio plug.
I know for a fact I have all of the speakers correct and thought I had most of the other things right, But found out I was wrong.
Once I got the radio and everything else together I couldn't get the screen to turn on. The face will open and it will take/ eject CDs but the screen does not work and it seems like it is not powering on all the way?
Now I am going to go through a quick overview of everything I did. (besides speaker wiring)
I ran the yellow 12+V wire to the 12+V wire coming out of the radio Harness
The ground went to the ground in the radio harness
The Amp on wire ran back to my kicker amp in the trunk
*** these are the wire's that I am not sure if I hooked up correctly***
I ran the orange white wire (Illumination) from the unit to the instrument Panel Lamp supply voltage- (1) in the car radio harness
I ran the Auto Antenna from the unit to Antenna enable signal in the car radio harness
There is also A red wire coming out of the clarion unit labeled +12V Accessory. I have no Idea where to wire this. What is it for?
Did I do this right? I tried to be as specific as I could be. My guess would be that I messed up somewhere with the 12v accessory wire or the main 12v wire coming in. Do I have to run another wire somewhere or switch them? and is it alright that I have the ground going to the ground in the radio harness or should I try to mount it to the chassis somewhere?
I'm sorry for giving so much info, asking what may be a lot. But the Installation manual is VERY very vague, and I couldn't find anyplace else to get the information from. Thank you in advance for any help you can give me. And if there is any other information that would be helpful please just let me know.
Thanks again for any help!!!
