Need help wiring Cap...plz help
Ralphy56
Ok, so how would i go about doing this, do i wire the power cable from the battery directly to the cap..then into the dist. block. or do i wire the power cable into the block, and then wire to cap, then shoot it to the amp? Running 2 amps*.
Any help appreciated, thanks:D
If you really want the cap then whatever (it's sort of a band-aide...not necessary)
If you really want improvement in your electrical, get another battery and/or do the big 3.
The only use that a cap really shows me is for a voltage meter, and that's only if it has a digital read out.
a cap?
Ralphy56
Ralphy56
Los Angeles
skittlesRgood
Mike Mccabe
