Need help wiring an equalizer
ak49
So my buddy gave me and equalizer with subwoofer out because my HU didn't have any, but i don't know how to hook it up. The EQ says on it "Boss Pre-Amplifier Equalizer with Subwoofer" model AVA 1206
Wires are as follows
Black-Ground
Red-12 volt power
Orange-Acc/car st
gray 1-right input +
gray 2-right input -
brown 1-Left input+
brown 2-left input-
Seems pretty straight forward but i dont know how to wire it into my stereo/harnass?
Do i match up the EQ+HU wires such as take both Right impute + Wires, twist them together then solder them to the harnass/plug adapter wire? That is also right input +?
HU \
(Twist/Solder/Wrap)X---------Wiring harnass/plug
_________
EQ /
on the deck there is 1 pair of RCA outs, L and R, on the EQ ther eis rear LR FRont LR sub LR and low-level input LR
so how do i wire thsi thing in lo0l?
Still clueless :/ trying to search info on it, not having any luck? so i just splice into my hu power/remote/ground, and run the rcas from my hu>eq>amp?
Run the L/R RCA's from the HU into the inputs of the EQ, then the sub outputs on the EQ to your amplifier.
Black is ground, Red goes to the +12v constant (probably yellow on the HU), Orange goes to +12v switched (Red on HU).
ak49
ak49
Suprise?
ak49
