need help wiring again
YoungBuk
hi guys. i have a 2 channel 4/2 ohm amp. how do i wire 2 dual 4 ohm subs to present a 2 ohm load? i bridged the amp and wired it all to a 8 ohm load but it was just to weak for me. also i have 1 jl daul 4 ohm is there a way to wire it to see a 2 ohm load?
What amp are you running?
You can only wire two dual 4ohm sub to 1ohm or 4ohms, you cannot wire them to 2 ohms.
Also, I'm guessing your amp is 4ohms stable when it's bridged, so you would need to wire your subs to 4ohms.
YoungBuk
YoungBuk
chicago
BassAce
