need help wireing the 2 12' Subs
jamezruiz
i got 2 12' inch Premier subs 1200 watts each and 400 RMS each 4OHM dvc
here is the specifications of the Kenwood KAC-9103D :
1800W Mono Subwoofer Amplifier
RMS Power Range : 500-900 Watts
Number Of Channels: 1
Maximum Power: 1800 Watts
Low Frequency response: 20 Hz
High Frequency Response: 20000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
RMS Power @ 4 ohms: 500 Watts x 1
RMS Power @ 2 ohms: 900 Watts x 1
CEA-2006 compliant
Top-Mounted controls
Preamp Outputs - 1 Pair
Power MOSFET Switching Power Supply
Variable Low-Pass Filter: 50 - 200 Hz
Infrasonic Filter: Off / 15 / 25 Hz
High- and Low- Level Input
Adjustable Input Sensitivity: 0.2 - 5V
Bass Boost Control: 0 - 18 dB
Class D Amplifier Circuit
RCA Inputs/Outputs
Fuse Rating: 30A x 2
Signal-to-Noise Ratio: 94 db
Dimensions: 11-1/4" L x 14-15/16" W x 2-9/16" H
whats the recomended wireing?
i have them and purchased them in 4ohm mode lol not a wise choice. well they are currently wired to 2ohms each and arranged in series to a cheapo amp. will that still work fine?
okay so can any one tell me if i am able to wire two 4ohm subs to get a 1ohm load and 2 ohm load an a mono block?? and how would i do it
looking to buy this Kenwood KAC-9104D
Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: >900 watts x 1 chan.
Max power output: 1800 watts x 1 chan.
MOSFET power supply
LED power indicator
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Stackable operation capable
Phase inverter (0°,180°)
Speaker-level inputs with signal sensing for automatic turn-on)
Preamp RCA outputs
Short circuit, DC offset, overload, and thermal protection circuitry
Aluminum die cast heat sink
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable low-pass filter (50-200 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 5-200 Hz
Dimensions: 13-3/4"L x 2-5/16"H x 9-3/8"D
8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
jamezruiz
jamezruiz
Russellville, AR
jamezruiz
