Need help!! Will this hurt my sub?
sdimeconcept
I built a box for my Type R 10 the other day. I had the volume at right over 1 cubic feet. I built the box a little big, but when building the box, we built the box a tad bit bigger. Alpine says a ported box should be built between .8 - 1.25 cubic feet. This box is 1.97 cubic feet. I haven't calculated the room the sub takes up, or the 3" pvc port at 7.25 inches at 32 hz.
Will having that much extra room damage the sub? Should i build another box or will this one work?
Thanks!
You need more port.
4" aero, 12" long will put You at 1.7 ft @ 36hz
Roughly double the area.
You want (ideally) 10 in^2 of port per ft^3. This figure, is up for debate.
So port placement really doesn't matter then? It's an L shaped box...
Can you place both ports on the same side? The box is only 24 inches long in the back...
Not sure exactly how to place the ports...
sdimeconcept
sdimeconcept
East TN
pwnt by pat
