need help using a DMM
norcalSRTrida
norcal209
i assume your trying to set your gains...
Connect the wires to the speaker outputs, with HU volume up around 3/4 with the desired test tone. Turn it to AC voltage 50 and set the gains from there. If you have over 50 volts, turn it to the next highest setting...
i disconnected my wires from the speaker outputs and inserted the prong thingys from the DMM.
i had my volume set at the desired level and played a repeated 50hz sine wave.
i dont understand the AC voltage 50? i set it to the AC setting and everytime i turn up the gain, voltage goes down and vice versa...i cant put my finger on why its doing that.
thats exactly what its supposed to do. "turning up the gain" as you say, is just setting the input voltage higher. when you set the input voltage all the way up to 8 volts when you HU is only 4 volts, then then volts (power to your speakers) will drop.
that explains it. thanks for the insight.
norcalSRTrida
norcal209
norcalSRTrida
Tracy, Ca
norcalSRTrida
