Need Help: Trouble wiring my new head unit
cnoxin1234
I recently bought a new head unit Pioneer DEH-P5900IB and a wire harness to go with it. I need help installing the head unit in my 1995 4runner. I am not experienced with car audio installation so this should be a breeze for you guys.
The factory wiring has two wire harnesses coming from it, one has 8 wires the other has 4 wires.
8 wires:
(color - what the wires say on them)
Reddish orange - 12v ignition/acc
Blue - power antenna
Black - ground
Yellow - 12v batt/memory
White - LF(+)
White w/stripe - LF(-)
gray - RF(+)
gray w/stripe - RF(-)
4 wires:
Violet - RR(+)
Violet w/stripe - RR(-)
Green - LR(+)
Green w/stripe - LR(-)
I am going to solder these wire harnesses to the new harness that I bought with my Pioneer DEH-P5900IB
however the new harness has 14 wires
14 wire harness
(color - what the wire says on it)
Red - 12 Volt
Yellow - Memory
Black - Ground
Blue - Power Antenna
Brown - Mute
Orange - Illumination
Gray - RF(+)
Gray w/stripe - RF(-)
White - LF (+)
White w/stripe - (LF-)
Violet - RR(+)
Green - LR(+)
The ground/power antenna/ speaker wiring are pretty straight forward but I am confused about the rest.
*Which wire on the old harnesses go to which wire on the new harnesses?
*What do I do with the two extra wires (orange and brown) on the new harness?
*Does this mean that the receiver will not be able to illuminate and/or the mute function won't work?
*Do I need a new harness (This is a last resort because I am broke :& )
Thanks For all your help. Any help is appreciated.
the orange wire is a dimmer wire so when you turn your headlights on it dims some cars dont have that the brown one is prob for a phone mute
Yea don't worry about orang and brown. Just cut off the wirin coming out of it and tape it up. Match up everythin else and if u plan on installin an amp later on then that goes to blue/white
cnoxin1234
cnoxin1234
Idaho
dredey
