need help, suggestion subwoofer
The Kenwood KAC-X811D will supply 500 watts RMS into a 2ohm load.
An appropriate sub would need to have an RMS rating close to 500 watts RMS, so around 400 to 600 watts RMS. The sub will also need to have a nominal impedance of 2ohms, a dual 4 ohm voice coil sub can be wired in parallel to present the 2ohm load.
If you want to run a pair of subs then you would look for subs with an RMS rating of around 250 watts RMS each with each sub having a 4ohm voice coil so the pair can be wired in parallel for the final 2ohm load.
The amplifier is rated to handle a 1ohm load but some X811D owners have reported overheating issues when using them this way. It will however stay dead reliable at 2ohms.
How much do you want to spend on the sub woofer?.
How many sub woofers do you want to use?.
What size of sub woofer?.
thank you for try support me.
http://carlife.carview.co.jp/Image.asp?src=http%3A%2F%2Fcarview.r3h.net%2Fimages3.carview.co.jp%2Fcarlife%2Fimages%2FUserCarPat%2F105334%2FP1.jpg my car same at this, and this owner have put 10" sub.
so, any recommend. 2 for 10" or just 1 12". and not so expensive one. below 200, what brand can get for this range.
thank you for try support me.http://carlife.carview.co.jp/Image.asp?src=http%3A%2F%2Fcarview.r3h.net%2Fimages3.carview.co.jp%2Fcarlife%2Fimages%2FUserCarPat%2F105334%2FP1.jpg my car same at this, and this owner have put 10" sub.
A single 12 inch 4 ohm Alpine type R would work.
Another option is a pair of Pioneer TS-W256c 10 inch subs.
A pair of Eclipse SW4000 10 inch woofers would sound nice as well.
A JL audio 12W3V2 single 12inch would also work well.
There is many possibilities and even more manufacturers.
A single 12 inch 4 ohm Alpine type R would work.Another option is a pair of Pioneer TS-W256c 10 inch subs.
thanks alot....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif Where the HELL have you been?
my friend is running that amp with one 10" eclipse sub, and it sounds pretty nice. i have the older one (KAC-X810D) pushing 2 12" Xtants, and they rock with it.
stvse
stvse
MAL
PatFitz9
Mike Mccabe
