Need help running wire through doors to 6.5 Please
Ksan
Dodge HEMI
OK I wanted to run the speaker wire through the black hose that runs through the door but the inside of the door it is a plug with wires and their is no way to go through it. I was hoping I could use the wires already their on the stock system and then pick them up behind the head unit but isn't the front speakers on some kind of a stock amp? Can I run my kicker amp through this amp Without harming anything?
Can I wire them this way or does anyone know how I could get wires to the speakers, it is a 6.5 component Polk Audio set I am wiring up....Thank you for your help and knowledge.
I've seen a tutorial on how to do this. I can't remember if it was on this forum or another.....
But iirc, you can find a spot in the connector that isn't being used and drill a hole through both ends to run your wires.
Search around and you should be able to find that tutorial. Its either from here, the12volt, or mp3car.....
Drill/cut through an open spot in the molex or run speaker wire up to your deck harness and wire into the stock wiring there.
Molex's are my least favorite thing in the world....they eat dicks
Ksan
Dodge HEMI
Ksan
Louisianna
allout13
