Need help quick! Memphis mojo 2500 vs kx2500.1
Unless Memphis has updated their POS design that leaves the circuit board mostly supported by the MOSFETS, I say go with the kx2500.1! Then again, I haven't used a POS Memphis Car Audio amp since 2007, so the lack of circuit board support may be fixed by now.
hows your electrical? the kx is going to be more efficent. the mojo will go lower for burps. ive used a few kx 2500.1's and sometimes they play 1 ohm nominal, sometimes they dont and cut out on heavy bass notes. both are great amps, as much as i love kicker 2500's you're probably better off with the mojo.
Williams37
Williams37
Toledo, Ohio
BassAddictJ
