One solution but the bottom of the tank is full of crap bad for the engine considering its a 1990Just run it out of gas, haha. Or you could syphone? all of the gas out and let it run till it dies.
see my last replyAight, we got it finally lol
well since the key is still seized up in the ignition, do u think the ignition went out???
lol alright thx...push rod?Pull fuel pump relay under hood then disconnect battery...go inside have a beer sit down relax and tomorrow you will have to replace either the ignition switch or the push rod inside the column.
lol but there was a full tankJust run it out of gas, haha. Or you could syphone? all of the gas out and let it run till it dies.
what you do?Aight, we got it finally lol
because i take a dump in my tank everytime i fill up my car? its just gas in there, maybe a little bit of build up from crappy gas but a v8 should be able to power through crappy gas. if not, fill it up with a gallon and drive it 1/2 mile before you run out.One solution but the bottom of the tank is full of crap bad for the engine considering its a 1990
There is no risk in killing his fuel pump. Its just like running out of gas on the road.i wouldnt risk anything like that just take its air away and deal with the key after or grow a pair and get the key out urself w/o killing the truck
the ignition switch may have, the ignition im sure is fine. sounds to me like a problem inside of the steering column.Aight, we got it finally lol
He could kill ignition but pulling all the wires would be a bad idea. You can easily kill Body control modules by letting a plug wire short to ground on newer cars.Think, you have to rob it of fuel, air, or spark...
Which one is easiest.
*Think spark, think of the wires....*
unplugged the alternator then disconnected the positive battery terminalwhat you do?
lol im extremely limited...im only 17the ignition switch may have, the ignition im sure is fine. sounds to me like a problem inside of the steering column.
No offense but you have no idea about auto mechanics, do you?
