Need help...POWER INVERTER
I would get a 700watt or higher just to be on the safe side. And if you have a few extra watts who knows you might need to plug something in sometime.
i'd say thats a bit overkill and going to be rather expensive too, if it needs 120 watts peak, get a 300 watt peak inverter, unless you will weant to hook up other things later then you can get one slightly larger
Thanks guys...so a 300 watt inverter should be plenty? what about this other junk
INPUT
100-127/200-240v~
4.0/2.0A 50-60Hz
^should i have to worry about that or just the 120w output?
i can get a 300w inverter for about $45 and a 700w for $70...What you guys think
YoungBuk
YoungBuk
chicago
djman37
