need help plz
What make and model? Some cars, like Honda, have a special tool to hold the pulley. If you have a strong enough impact gun you can break it loose without needing to hold it. It took 450+ ft-lbs to break my Accord's loose. They're notoriously tough though.
Check a pickle fork or breaker bar against the teeth of the flywheel. Might have to pull the starter to do so. Quickest method of removal on a clockwise-rotating engine is a starter bump. Quickest, but not always best for first timers. Get a breaker bar or lifetime-warrantied ratchet, but a SHORT socket on it, and put it on the bolt. Rest the handle on the ground pointed towards the right, disconnect the coil wire, and BUMP the starter. 1 very quick turn of the key should do it. Also, aftermarket crank pulleys are about the worst thing you could possibly do to your car.
CRAZYCORNUTS18
Registered User
CRAZYCORNUTS18
PAT
Ferendon
