Need help please
yroc434
Va
ok so i just ordered (2) SA 12D4's and i want to go with a ported box! now my question is, it recommends for a ported box , 2.0ft^3 (tuned to 35hz, yields F3 of 28hz)..... ok now here is my question..... since im getting (2) 12's do i go with a 4.0ft^3 box ? do i double the 2ft^3 since im getting (2) 12's or do i need a box thats just 2ft^3????
***STILL LEARNING CAR AUDIO***
Right^^^ and just in case, allow me to elaborate... Displacement is the space your subs as well as the port in your box use up, so your box may need to be 4.75 cubes before displacement (example) .. And of you need to know what your sub displacement would be for each sub you can find that in sub specs.. Good luck
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
987
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
986
Start off by making sure the ground is making contact with bare metal. Then check that the fuse holder wires by the battery are snug. When I have...
yroc434
yroc434
Va
DCbass
