Need help on wiring...
drockstar
I want to run (3) 6.5" and (2) 1" tweets in each door, all 4 ohm. I also want to run a pair of 3" in the dash. No passive x-overs. I have (2) 4-channel amps, one of which will run 4 tweets and 4 - 6.5". My question is how can I use two-channels from the second amp to run the third set of 4-ohm 6.5s while matched to the 4 6.5s on the first amp running at 2-ohm? The other two channels would be dedicated to the 3"s in the dash.
The amps are identical.
You would use 2 channels to run the 6.5’s @4 and 2 channels on the 3.5’s. Let's say your amps are 100x4@4 200x4 @2..... each 6.5 would be seeing 100 watts, each tweeter 100 watts, and the 3.5’s 100@4 watts.... or am I missing something?
Yea I thought of that but it's not an even double with my amps. They are 240 watts @ 2 ohm but 160 @ 4 ohm. So I'd have two 6.5" on 120 watts and the other at 160.
just do it like garychoffman said. dont know why you would want or need to do it a different way unless you are going for sq but with 4 12's I doubt that is the case.
drockstar
drockstar
Shreveport, La
CrossoverOre
