need help on how to wire 2 subs to 2ohms
  • 2
hondaracer48
texas
I have 2 cvr102 that are dual 2 and have 4 coils. I looked at a pic an did what I thought and want to clarify. I ran a short wire neg. To neg pos. To other pos on back of subs. I twisted 2 wires together and put them in the voice,coil 1 and ran it to the terminal on the box. Then I ran both subs to the amp and tied positive from both subs d hooked it up an neg. From both subs and hooked to neg on sub. Is this right?
You may have to drill a hole in the divider to connect to the other sub if you have only 1 speaker terminal or if you have 2 speaker terminals you can just wire it 1 + and 1 - to the terminal and the + and - from the terminal to the amp for each side
---------- Post added at 07:09 PM ---------- Previous post was at 07:08 PM ----------
4 all together, one negative and one pos. on both sides
could you post a pix of this
i cant figure out how to upload a pic. so do i wire one pos. to neg with a short wire. then can i run the left over pos and neg to the box terminal. do this with both subs. then tie them together at the amp input?
691
966
933
hondaracer48
hondaracer48
texas
hondaracer48
