need help on cap install
  • 3
bronco2323
house
alright i get how to charge it and everything but running the power wire to cap is what im confused on.can i just cut the power wire and attach both ends to the 1 screw thing or do i have to have another wire that comes from the power wire .
or whats the best way to hook it up. thanx
Power wire to a distribution block. from there one power wire goes to the amp, the other goes to the + terminal of the capacitor. the other terminal of the cap goes to the same ground as the amplifier.
ok so what ur sayin is i got my 4g to a dblock and 1 8g to 1 amp and another 8g to my other amp and another 8g to the cap.(that was my first idea but i wasnt sure if it was gonna work right).thanx
ok how about if i cut the power wire in half and connect both ends to the positive terminal and then ground the other . wouldnt that werk?
Originally posted by bronco2323 ok how about if i cut the power wire in half and connect both ends to the positive terminal and then ground the other . wouldnt that werk?
the MAIN wire?
you really don't want a distro between the cap and the amps
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
11
718
760
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
978
bronco2323
bronco2323
house
bronco2323
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
