Need Help... Imput on my future set up.
ok so I decided to drop the RS65's and go with the PG RSD65CS's for the components and since I'm gonna go with a 4 channel amp can't I juse bridge 2 to the L7 at 325 RMS and use the other 2 channels for the front stage instead of buying a separate amp? I really don't need the sub to be really loud so I think that wattage should be fine.
Need to know if this set up would work so I can start buying it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Kicker ZX650.4 :
* 4-Channel ZX-Series Power Amplifier
* Low Impedance Operation
* SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
* MOSFET Power Supply
* KickBass: 0-18 dB @ 40 Hz
* Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
* High & Low level inputs
* Custom tooled gold plated connectors
* SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
* Cast aluminum EndKaps
* RMS Power Ratings:
* 120 watts x 4 chan. @ 4 ohms
* 170 watts x 4 chan. @ 2 ohms
* 325 watts x 2 chan. @ 4 ohms Bridged
* Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)
PG RSD 65CS:
*Power Handling: 60W/120W (RMS/Peak)
*Impedance: 4 Ohms
*Frequency Response: 45Hz - 20kHz
*Sensitivity: 88dB
single Kicker S10L7
*Dual Voice Coil
*Impedance 2 ohms
*Peak Power Handling 1200 watts
*RMS Power Handling 600 watts
*Sensitivity 86.1 dB
I want to bridge 2 of the channels on the amp for the sub at 4 Ohms and use the other 2 channels for the RSD's I just want to know if this is possible and would it work correctly? I'm still new so I also wanted to know since the Sub says "Impedance 2 ohms" will I still be able to wire it up to 4 ohms to the amp with no problems?
thanks
Antics
Antics
Rancho Cucamonga, CA
Twilight
