need help from computer guru
Savstyle
well i downloaded a game the installer is an mds file type and game is mdf file type. my question is what program can i use to make them run? if i double click on them it send me to a site telling me they dont know what program works with these file types. so if you have an idea lemme know. also if u have AIM hit me up it might be a little easier that way
AIM:Niggz89
thanks
is it an ISO type file? cuz then you have to make a virtual drive and mount it useing ilke daemon tools
dont see anything saying anything about ISO file, 1 is mds the other is mdf. the mds says its the installer the mdf is the game i beleave
ya im an idiot i meant image file and i think daemon tools is a lot easier to use than alcohol, also get virtual drive creator and you will be able to make all the virtual drives you want
Maybe im a little late here but Daemon tools is the way to go here.
Its a great freeware program that lets you mount images to virtual drives. Those files you have are images and all they need is mounting unless you want to burn them, then you could use Nero or Alcohol and the list goes on.
I agree. But this is probably because I hold a vendetta against alcohol 120%. Daemon tools is just so much easier to use. Although that image was created with alcohol 120%, your best bet is to mount it to a virtual drive via daemon tools.
Alcohol 120% will definitely workDaemon Tools will work if it supports .mds/.mdf format
I think burning both the images to CD would also work
The reason I'm iffy on the last two is because I use Alcohol 120% Virtual Drives pretty much exclusively ...
x2
A120% is the shiznit
Savstyle
Savstyle
Fresno
HiAmplidude
