ok i opened the amp it looks good inside no burn areas i seen only problem is the connectors for the remote wire and the speaker wires connector are broke off the terminal so it looks like it needs to be just soldred up how much would this run to fix
also if the remote wire cant be hooked up what if i connect the pos and neg from the amp straight to the battery it will at least turn on correct and stay on until disconnected and like that i can see if the amp is any good right
