2 x Bxi-2608D Strapped
Oinkypig
MI
hey im getting 2 Hifonics BXi-2608D amps to power 2 x Fi 15" BTLs. Is this amp strappable? If so, how many ohms must i run the amps at in order to acheive 5200rms. 1 or 2 Ohms? Should I strap the amps or should i run each amp individually to each each sub?
i can get BOTH of the BXi-2608D amps for only $650. I was seriously considering on getting the XXV Golaith BUT it cost about 850-1200. I dont have that much money right now. i will be getting 2 15" Dual 2 ohm Fi BTLs. so i can either
1.run 1amp to 1 sub=1 ohm
2.run both amps to both subs(strapped)=.5 or 2 ohms(i would do .5) if it is stable
i can get BOTH of the BXi-2608D amps for only $650. I was seriously considering on getting the XXV Golaith BUT it cost about 850-1200. I dont have that much money right now. i will be getting 2 15" Dual 2 ohm Fi BTLs. so i can either 1.run 1amp to 1 sub=1 ohm
depending on your ohm load you can do .25 and 1 ohm or .5 and 2 ohms that each amp will see. for daily i would not run .5 but for comps its fine. and of course you can also hifonics up and ask for mike steirs and he will answer all your questions.
Oinkypig
Oinkypig
MI
audioarsonal
