Need help finding inside airspace of this box...
F150Matt
ok guys I know that with a perfect square or rectangle you have to take away the width of the board from the outer dimensions which would (L-1.5)(H-1.5)(W-1.5) but look at this box and these measurements. I have a sloped front and a weird shaped back. I know I should be able to figure this out but my brain just isn't working right now. I came up with 8.122 ft^3 using the outer dimensions of this box. I believe it may actually be too big if I were to go all the way to the top of my back glass. Kicker recommends 3.25 max ft^3 per sub minus the cubic inches of the port, so I'm looking at about 7ft^3 I assume with the port??? Here is my drawing.
sorry guys that didn't come out very clear...anyway the bottom depth is 11.5, the width is 42.5, the hieght up to the protrusion is 14, he height from the protrusion up is 25, and the top depth is 6, all of these numbers are outer dimensions and are in inches. Thanks for the help.
F150Matt
F150Matt
Houston, TX
F150Matt
